Remove options from the Load Map dialog.
                Click the Load Map tool.
 The Load Map dialog opens.
                On the top half of the dialog, select a load channel and click  to delete it. to delete it.
                On the bottom half of the dialog, select an event or a subcase associated with
                    an event and click  to delete it. to delete it.
