Use the Weld tool to calculate fatigue based on a spot or
        seam weld analysis.
        At the moment, .odb and
                    .rst files are not supported
            for seam and spot weld analysis.
                Click the arrow next to the fatigue module icon and select the
                            Weld tool from the list
                    of options.
 The Weld dialog opens.
                Select SPOT or SEAM as the weld
                    type.
                Select the FE model units.
                Select a mean stress correction option.
                Based on the scatter of the SN curve, enter a real value between 0 and 1 for
                    the certainty of survival.
                Select Yes or No for thickness
                    correction.
                Enter a value for No of Angles on Sheet.
                    Note: This option is only available for spot weld analysis.
