Create Events with Fixed Points
Forego adding loads and create events that use a fixed number of time points.
- Subcases placed under each fixed points event are compared to pick a max and min point which will constitute the fixed stress range.
- For the Eurocode 3 specification, multiple events created are passed as separate
                    ranges to create cumulative damage.Cumulative Damage = Damage from Event 1 + damage from Event 2 + … damage from Event n.
Import and Export Range Definition Files
Range definition files (*.rdf) help create fixed range events automatically.
The LCF is used to create the derived loadcases, which are then used to define fixed ranges via the RDF.
#PARAM and should contain the following data in the sequence
            mentioned below:- A #RANGEStag to indicate the start of the definition of the ranges.
- Range detail with the id, lower limit, upper limit, and the range name, as shown in the example below.
Figure 6. Example Range Definition File
 in the bottom
                    half of the dialog to create events manually or automatically.
 in the bottom
 and
 and  icons on the bottom-half of the dialog to import or
                    export an
                    export an
