Auto-extraction from the FE model allows for a quick recovery of the seatbelt system
        without having to recreate the seatbelt.
            If an FE model is imported with a seatbelt system without seatbelt metadata defined
                in the solver input deck, there is no seatbelt system in the
Seatbelt Browser.
Note: Seatbelt auto-extraction is only available in
                    the LS-DYNA user profile.
                To open the seatbelt auto-extraction GUI, right-click in the Seatbelt Browser and select .
The seatbelt auto-extraction GUI appears in the Entity Editor.
                To extract the seatbelt model:
                        Type a name for the system into the SeatBelt System Name field.
                        Select all components that define the seatbelt system to be extracted
                            (1D components, 2D components, and so on) in the Seatbelt Mesh
                            Components field.
                        Select all components that are in direct contact with the seatbelt in
                            the Wrap Around Components field.
                        In the Start Entity field, select from which entity the seatbelt system
                            starts. This can be a node, element, constrained extra node, or
                            retractor.
                        In the End Entity field, from which entity the seatbelt system ends.
                            This can be a node, element, constrained extra node, or retractor.
                    - Optional:
                        Select contacts between the seatbelt model and the wrap around
                            components if they already exist.
                        Click Create.
The seatbelt system is automatically extracted and exposed in
                            the Seatbelt Browser.
