Use the Seatbelt Browser to create a complete seatbelt
        system.
            Restriction: Only available in the LS-DYNA,
                    Radioss and PAM-CRASH
                solvers.
            The Seatbelt Browser consists of two panes. The upper pane is the
                Seatbelt System structure and the lower pane is the Entity Editor.
                From the menu bar, click .
The Seatbelt Browser opens. To undo or redo actions, use the Undo and Redo commands on the Restore
                        toolbar.
                Add or remove columns in the Seatbelt Browser as necessary
                    by right-clicking a column and checking or unchecking the appropriate
                    attribute.
                You can sort entries in the browser by clicking on the
                    appropriate heading of each column. For fields that are numeric or alphanumeric,
                    repeated clicks toggle between ascending and descending order.
                Create a seatbelt system:
                        In the Seatbelt Browser pane, in empty space,
                            right-click and select .
A seatbelt system is created and displays in the browser.
                        Edit the seatbelt system entity as necessary by setting or changing
                            values in the Entity Editor.
                To update a seatbelt system, right-click the appropriate
                        SeatbeltSystem entity and select
                        Update from the context menu.
Updating allows you to make changes on demand. For example, when the dummy and
                    seat positions have been modified (when the option Link Dummy Mechanism in the
                    seatbelt system Entity Editor is OFF).
                Run a penetration check on the system by right-clicking the appropriate
                        SeatbeltSystem entity and selecting
                        Penetration Check from the context menu.
A penetration check allows you to directly check the generated contact for
                    penetrations after a seatbelt mesh has been generated and the option Create
                    Contact is activated.
