Analyze Data Sources
Build arrays of information based on data sources using the row and column index.
- From the Post-Processing step, click the Data Sources tab.
 - From the Channel selector, select a data source.
 - Select the Table View.
                Build a table using the Index column, Row Index checkbox, and the Column Index
                    checkbox.
 - Analyze the table.
