Define Goals (Objectives/Constraints)
Goals are used to define objectives and constraints.
                Define goals for the active output response.
- Go to the Define Output Responses step.
 - Click the Define Output Responses tab.
                        In the Goals column, click
                        A dialog opens. - In the Type column, select the type of goal to create.
 - In columns 1 and 2, define additional options as needed.
 - Click OK.
Figure 1. -
                Define goals manually.
 - Click the Objectives/Constraints - Goals tab.
 - Click Add Goal.
 - In the Apply On column, select the output response to which this goal will be applied.
