Pareto Plot Post Processing
Plot the effects of input variables on output responses in hierarchical order (highest to lowest).
Plot the Effects of Variables on Responses in Hierarchical Order
Rank the effects of input variables on output responses in hierarchical order (highest to lowest) in the Pareto Plot post processing tab.
Pareto Plot Tab Settings
Settings to configure the plots displayed in the Pareto Plot post processing tab.
- Effect curve
 - Show line to represent the cumulative effect.
 - # Top factors displayed
 - Specify the number of input variables (bars) displayed in the
                                plot.Note: This settings does not change the calculated effects.
 - Multivariate Effects
 - Calculate the effect using all input variables simultaneously.
 - Linear Effects
 - Calculate the effect using each input variable independently.
 - Include Interactions
 - Include first order, two way interactions along with first order effects, and calculate interactions consistently with the choice of linear or multi-variate effects.
 - Exclude dependent/linked inputs
 - Only show the independent input variables.Tip: Excluding dependent/link inputs reduces redundant information.
