Select the solver execution script you would like HyperStudy to use
        when executing the model.
        A set of default solver codes are registered in
                HyperStudy. You will need to register solver scripts if the solver
            is not a HyperWorks solver and hence is not registered by
            default, or in cases where you need to perform a series of actions such as copying
            files, running one or more solvers, and extracting data.
                In the Define Models step, Solver Execution Script column of the model you are
                    defining, select a solver script.
