plt3DIWaterfall GetMeshColor
Gets the color of mesh lines superimposed on the waterfall.
plt3DIWaterfall_handle GetMeshColor
HyperWorks Tcl Query
The string returned will be either a color name, if the RGB values of the color match a name, an index, if the value matches one of the standard palette of colors, or a set of three RGB values. Returns a color identifier string.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName 1
myWaterfallName GetMeshColorErrors
None.
