plt3DIWaterfall GetNumberOfSlicesOnClipboard
Gets the current number of curves on the curve clipboard.
plt3DIWaterfall_handle GetNumberOfSlicesOnClipboard
HyperWorks Tcl Query
All waterfalls share a single clipboard, which can contain (in theory) one or more slices. The current implementation limits the number of slices that can be on the clipboard at a time to one (or zero). Returns the number of curves (currently zero or one).
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName 1
myWaterfallName GetNumberOfSlicesOnClipboardErrors
Returns an empty string if the value is not defined.
