pltIDataAttribute GetValue
Gets the value for a data attribute.
pltIDataAttribute_handle GetValue
HyperWorks Tcl Query
Returns the data attribute value.
None.
View new features for HyperWorks Desktop 2022.2.
Gets the label for a data attribute.
Returns the type of data attribute.
Gets the variable name for a data attribute.
Sets the label for a data attribute.
Sets the value for a data attribute.
None.
