pltILegend SetColor
Sets the legend border to the specified color.
pltILegend_handle SetColor color
HyperWorks Tcl Modify
Color values range from 0-63, with 0 corresponding to black.
Returns 0 if successful; error code (see below) if unsuccessful.
- color
- Integer value corresponding to the desired color of the legend border.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWindow 1
myWindow GetClientHandle myClient
myClient GetLegendHandle myLegend
myLegend SetColor 6Errors
3 = HW_InvalidHandle ("Handle is no longer valid") if the handle is invalid.
4 = HW_InvalidArgs ("Invalid command args <arguments>") if the number is less than 0 or greater than 63.
