poIFLDCtrl SetEnableState
Sets the auto load/unload FLD data state.
poIFLDCtrl_handle SetEnableState state
HyperView Tcl Modify
This command sets the auto load/unload FLD data state. Setting the enable state to false causes the currently loaded data to be unloaded.
- state
 - True if FLD data can be loaded, or false if not.
Returns 0 if successful, otherwise an error code.
