poIMeasure AddEntity
Adds the given entity to the measure from the specified model and pool.
poIMeasure_handle AddEntity id_str
HyperView Tcl Modify
This command adds the given entity ID/s in the current measure group from the specified model and pool.
- id_str
- Can be one of the following formats:
- Regular Nodes
"node model_id [node_pool] n1"- Param Nodes
"node model_id [node_pool] n1 n2 %1"- Param-Param Node
"node model_id [node_pool] n1 n2 %1 n3 n4 %2 %3"- Elements
"element model_id [element_pool] element_id"- Components
"part model_id [part_pool] part_id"- Systems
"system model_id [system_pool] system_id"
Returns a non-zero value.
