poIPostManager AddModel
Loads the given model file. A reference to the model needs to be attached to a post client window using AddModelReference.
poIPostManager_handle AddModel filename reader_name
HyperView Tcl Modify
This command loads the given model file. A reference to the model needs to be attached to a post client window using AddModelReference.
- filename
 - The model file name.
 - reader_name (Optional)
 - The model reader name.
Returns the model ID, or 0 if AddModel fails.
