poIResultCtrl GetFLDCtrlHandle
Gets a handle to the FLD control object.
poIResultCtrl_handle GetFLDCtrlHandle handle
HyperView Tcl Query
This command retrieves a handle to the FLD control object.
- handle
- The FLD control handle to be set.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle 1
model_handle GetResultCtrlHandle result_handle
result_handle GetFLDCtrlHandle fld_handle
hwi CloseStackErrors
Returns 0 if successful, otherwise an error code.
