poIResultMathCtrl GetNumResultMathResources
Gets the number of additional result files that were loaded while using the Result Module to load models into HyperView.
rmath_handle GetNumResultMathResources
HyperView Tcl Query
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
# Add 3 Result files (bumper, bumper foam, airbag)
set mid [client_handle AddResultMathAnalysis "Standard", "c:/samples/bumper/d3plot", "c:/samples/bumper/d3plot", 0, 0, "c:/samples/bumper_foam/d3plot;c:/samples/airbag/d3plot"]
client_handle GetModelHandle model_handle $mid
# Get the resource label/filename corresponding to the 3 subcases
set nres [model_handle GetNumResultMathResources]
hwi CloseStackErrors
None.
