poIScalarDefine GetIsMultipleLayers
Gets the multiple layers state.
poIScalarDefine_handle GetIsMultipleLayers
HyperView Tcl Query
This command, valid only in Upfront Data Loading Mode, returns true if multiple layers is enabled for this result definition, false otherwise. This will be true if the layer is Top/Bottom for this result.
To check if a result definition has multiple layers enabled:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine GetIsMultipleLayers
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
