poISystem SetOrientationByNode
Sets the orientation of the coordinate system using three nodes.
system_handle SetOrientationByNode node1 node2 node3 [movetype]
HyperView Tcl Modify
This command sets the orientation of the coordinate system using the coordinates of three nodes. The orientation can be set for user-defined systems only! Node1 defines the origin of the system, the vector between node1 and node2 defines the X-axis of the system, and node3 defines a point on the XY plane.
- node1
- The ID of node1.
- node2
- The ID of node2.
- node3
- The ID of node3.
- [movetype]
- The move type of the system: true - Fixed (Default), false - Moving.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetUserDefinedSystemHandle sys1 "UserSystem 2"
sys1 SetOrientationByNode "Node 100" "Node 200" "Node 300" true
hwi CloseStackErrors
Returns a non-zero value if there is an error.
