Constraint Mates
                                 Constraint mates offer higher pair constraints in the form of distance, coincidence         and tangency between two analytical
                                    geometries. The geometries could be point, line, sphere,         cylinder, cone or a plane. The geometry is defined analytically
                                    using bodies and points.
