Command Sets Panel - Properties Tab
Figure 1. Command Sets panel - Properties tab
- Write
 - Causes the Templex template to be written at that location in the solver command
                file.
Figure 2. - Forces
 - The *SetForce() command set statement writes a force statement to the solver command file. This statement sets the value of the force to the specified value when the solver acts on that line in the command file.
 - Simulate
 - Exports the simulation commands to the solver command file.
 - Motion
 - The *SetMotion() command set statement writes a motion statement to the solver command file. This statement sets the value of the motion to the specified value when the solver acts on that line in the command file.
 - SetState
 - One command set can be active in any one analysis task. MDL saves the state of each command set in the *SetState() statement.
