COSIN FTire Documentation
To specify and evaluate road excitation, COSIN/road uses one central subroutine evrmr (COSIN environmental models: road main routine).
- COSIN/io style 2D and 3D deterministic, stochastic, or measured obstacles/profiles
 - TeimOrbitâ„¢ style 2D and 3D deterministic, stochastic, or measured obstacles/profiles
 - RGR regular grid road models
 - COSIN road track files
 - User defined road models
 - Third party generally available road models (e.g. the CRG format)
Please refer to the respective original documentation to learn more about the availability of road models in your simulation environment, or contact info@ftire.com for more information.
The most important of these road models are documented in detail in the following sections:
