CVT for Scooter Models
- Internal Combustion Engine (IC Engine)
 - CVT
The powertrain model can read and interpolate a 3-D Engine Torque Map to determine the torque output of an engine based on vehicle states and throttle input. It further models a CVT which act as a clutch and also transmits the torque to the gear box and can be engaged, disengaged and shifts depending on the engine rpm. The following topics describe in detail the formulation used to model a Powertrain and describe the parameters that determine the functioning of it.
