Slip Calculation
Longitudinal Slip
The ratio between the contact patch longitudinal velocity and the wheel center longitudinal velocity.
Where
 is the longitudinal slip velocity of the contact point and
 is the longitudinal velocity of the wheel along
Lateral Slip
The angle between the lateral slip velocity of the contact patch and the longitudinal velocity vector of the rim.
Where
 is the lateral slip velocity of the contact point in the ISO
        coordinate system.
