Static Loads Analysis
A quasi-static simulation to study the effect of various load cases applied at the wheel center and tire patch.
Required input
- Point of application of the load (wheel center or tire patch)
 - Load direction
 - Load type (force or displacement)
 - Load in newtons, newton-mm. or displacement in mm
 - Load multiplier
 - Load case number that the load belongs to
Task Description
To begin with a static simulation is performed with all the active loads belonging to a load case. This is followed by resetting the set of loads in the load cases and the next set of load cases is applied. The process is repeated until all load cases are applied.
