Building a Full Vehicle Model with Advanced Drivers
Next we will go step by step from one window to another and explain the available options in each window to have a better understanding of the Assembly Wizard’s Full Truck with Advanced Driver model type.
- Select the Full vehicle with advanced driver option from the Model Type window and click Next.
                Select the Front wheel drive option for the model and click
                        Next.
Figure 1. -
                Select the primary systems for the model as shown in the following image and
                    click Next.
Figure 2. -
                Select the steering subsystems for the model as shown in the following image
                    and click Next.
Figure 3. -
                Select the springs, dampers, and stabars for the model as shown in the
                    following image and click Next.
Figure 4. -
                Select the jounce and rebound bumpers for the model as shown in the following
Figure 5. -
                Select the disk brakes and front drivelines for the model as shown in the
Figure 6. -
                Now, select the Advanced Driver system and click
                        Next.
Figure 7.Note: The Advanced Driver is now included as a system. -
                Now that you have selected all the required systems for the model, click the
                        Finish button to complete the assembly process and
                    exit the Assembly Wizard.
Figure 8.Note: Click Attachments button to proceed with the Attachment Wizard. -
                The Full Truck with Advanced Driver model built through the Assembly Wizard is
                    displayed in the graphics area.
Figure 9. - The subsystems you have selected in the Assembly Wizard to build the model are displayed in the Project Browser.
