Power-off in a Straight Line
A Power-off in a straight line event simulates the dynamics of a vehicle due to a sudden removal of drive torque.
The Altair Driver maintains the straight line path and controls the throttle. Engine motoring torque is not applied after the throttle torque is removed. A plot template is available to plot the results.
Event Inputs
Figure 1. Power-off in a Straight Line Event
- Event Parameters
Parameter Description Units Velocity unit selection (Model, m/s, km/h, mph). Velocity The initial speed of the vehicle during the steady state driven portion of the event. Throttle step begin The absolute time, in seconds, when the throttle torque begins to be removed. Throttle step duration The length of the time the throttle controller takes to remove all torque from the drivetrain using a step function. End time Absolute end time of the event, in seconds. Print interval Time interval of data output to the plot file (.plt) and graphics file (.h3d).  - Road Parameters
 - Use the road parameters to select the road that the vehicle drives on for the event.
              You can choose to use a flat road, a road data file you select from the event editor,
              or the road data files selected by tires. The table below describes the parameters in
                detail.
Parameter Description Road Selection This option menu determines the road selected for the event. There are three choices: - Flat Road - Use a flat, smooth road for the event. No road file is needed. Use the road settings to control the road graphics and road mu.
 - From Event - Select a road file from the event road file field. All tires in the model use this road file when running the event.
 - From Tires - For each tire in the model, use the road file selected for that tire in the AutoTire panel. This allows you to use different road files for different tires.
Road Selection = Flat Road When the road Selection is Flat Road, then the event is run on automatically generated flat road data file.
Mu (Friction Scale) Enter a value greater than or equal to zero that scales the tire-road surface friction. Note the tire-road surface friction is defined in the tire properties. So, if you enter a 0.5 here and the tire-road friction coefficient is 0.8, the effective coefficient of friction is 0.5*0.8 = 0.4. Show Graphics Check this box to create graphics for the flat road. Note the graphics are created when you click the Apply or Run button on the event editor. Graphic Settings Push this button to display a dialog that controls the flat road graphics, to learn more about the controls see the Road Settings section below. Road Selection = From Event Road File When the Road Selection option is From Event, use the road file field to select the road file for the event. Road Selection = From AutoTires
When the Road Selection is From AutoTires, then each tire runs on the road property file specified for it in the AutoTire panel. This allows the use of different road files for different tires, for example, one road for the right tires and another for the left tires to provide different vertical disturbance.
Driver
Use the Driver tab to set Proportional, Integral and Derivative (PID) gains and output signal filtering. The PID controllers employed by the Driver depend on the vehicle.
PID Controllers
- Lean PID
 - For leaning vehicles, the Lean PID takes as input a demand lean angle and outputs front fork (steering) angle. For open loop events the lean angle demand is a function of time. For closed loop path following events the demand lean angle is computed based on the vehicle speed and the path curvature with a correction for lateral path error. For more information see the Lean Angle Controller - Two-wheelers topic and also the Gain Tuning for Leaning Two and Three Wheeler Vehicles topic.
 - Lateral Error PID
 - For leaning vehicles, the Lateral Error PID takes as input the predicted lateral path error and outputs an increment to the demanded lean angle. The lateral error is computed by predicting the vehicle’s lateral position relative to the path by the look ahead time in the future. The Lateral Error PID acts to lean the vehicle toward the path. For more information see the Lean Angle Controller - Two-wheelers topic.
 - Longitudinal PID
 - You can add the longitudinal PID controller to any vehicle to correct for disturbances not accounted for in the feedforward section of the longitudinal controller and to remove steady-state error. The longitudinal PID takes as input velocity error and outputs throttle.
For more information see the Altair Driver Mathematical Methods topic.
Signal Settings
Use the signal settings to set minimum, maximum, and initial values for Steering, Throttle, Brake, Gear and Clutch signals output by the driver. The smoothing frequency is used to control how fast the Driver changes signals. Only closed loop control signals from the Driver are smoothed. Open loop signals are not smoothed.
Road Settings
The Road Settings dialog controls the display of the rectangular road graphics.
Figure 3. Road Setting Dialog
Grid Parameters
| Parameter | Description |
| View Grid Road | The View Grid Road check box toggles the road grid graphics on and off. |
| View Event Path | The View Event Path check box toggles the event path
                  graphics on and off.  Note: This check box is disabled for open loop events without
                    a path.
| Event Based Grid | Check the Event Based Grid option to automatically size the length and width of the road graphics based on the event parameters, like the initial straight and radius for the constant radius event. Remove the check from the Event Based Grid option to input the size of the road graphics. |
| Grid Square Size | Enter a positive value in model units giving the length and width of squares in the road graphics. |
| Grid Length | Enter a positive value in model units giving the length of the road graphics. |
| Grid Width | Enter a positive value in model units giving the width of the road graphics. |
| Grid X Offset | Enter a value in model units giving the distance to offset the road graphics in the longitudinal direction. |
| Grid Y Offset | Enter a value in model units giving the distance to offset the road graphics in the lateral direction. |
