Use the Reports tool to view the report definitions of
        associated analysis tasks.
            Every analysis task in MotionView has an associated
                report definition. The report definition describes the plots, text tables, and
                animations that are created at the end of a run. Whenever a model is run, the name
                of the report is placed in a report list. Report lists display the last 50 analysis
                runs in reverse chronological order.
            The reports log is in a file called .reports and its location is
                described in the preferences.mvw file with the
                    *RegisterReportsLog() statement.
                From the Analysis menu, select View
                        Reports.
The View Reports dialog opens.
                Select a report.
                Under Mode, select whether to overlay a report on top of another, append a
                    report, or replace old reports with new ones.
                Select overlay options.
                Click Apply.
The report is appended, overlaid, or replaced.
If a report definition
                        already exists, a message is displayed with the following
                        options:
                            | Overwrite |
                            Existing definitions are overwritten by new matching
                                definitions, one at a time. |
                            | Overwrite All |
                            All existing definitions are overwritten by the new matching
                                definitions. |
                            | Stop |
                            The operation is aborted. |
