TeimOrbit Format
Attributes
The TeimOrbit reader can parse various entities to get data from the ADF file. These entities include: attributes, blocks, subblocks, tables, units and comments.
[BLOCK_NAME]
ATTRIBUTE_1  = 'TRUE'
ATTRIBUTE_2  = 1.0
ATTRIBUTE_3  = 'GEAR_CONTROL'
ATTRIBUTE_4  = 8- Strings
 - Case insensitive, for example: TAG and tag are equivalent.
 - In the above example, the attributes are: TAG, SATURATION, LOOK_AHEAD_TIME, DEMAND_FILE, INTEGRATION_STEP_SIZE are the attribute names.
- Real, integer, string, bool
 - Strings should be written in ‘single quotes’ or “double quotes”
 - 0, 0.00, N, NO, FALSE, F are all depicted as false
 - 1, 1.00, T, TRUE, Y, YES are all depicted as true
 - Case sensitive
ATTRIBUTE_NAME = ATTRIBUTE_VALUEBlock
- Block can contain any number of sub-blocks.
 - Block cannot contain a block.
 - Block can contain multiple tables but only by storing them in different sub blocks.
[BLOCK_NAME]
ATTRIBUTE(s)
SUBBLOCK(s)
TABLEBlock ends with the end of file or start of new Block.
Sub-block
- A sub-block cannot contain more than one table.
(SUBBLOCK_NAME)
ATTRIBUTE(s)
TABLE(s)Table
- Table can contain any type of attributes.
 - In no label is provided, the default is to label them as indices starting from 0.
{LABEL1       LABEL2      LABEL3}
ATTRIBUTE00   ATTRIBUTE01   ATTRIBUTE02
ATTRIBUTE10   ATTRIBUTE11   ATTRIBUTE12
ATTRIBUTE20   ATTRIBUTE21   ATTRIBUTE22Units
- Every property sheet should necessarily have a units block.
 - User defined units in tables.
Comment
[VEHICLE_INITIAL_CONDITIONS]
$These are wrt marker attached to the driver analysis - Vehicle IC reference marker
$Default Global Frame
VX0 = -3.0
VY0 = 0.0
VZ0 = 0.0
