Model ElementAccgrav defines the acceleration due to gravity along the global X,
Y, and Z directions.
Attribute Summary
| Name |
Property |
Modifiable by
Command? |
Designable? |
| igrav |
Double (0) |
Yes |
FD Only |
| jgrav |
Double (0) |
Yes |
| kgrav |
Double (0) |
Yes |
Usage
Accgrav (optional_attributes)
Attributes
- igrav
- Double
- Defines the acceleration due to gravity in the global X direction.
- The igrav attribute is optional. When not specified, it
defaults to 0.0.
- jgrav
- Double
- Defines the acceleration due to gravity in the global Y direction.
- The jgrav attribute is optional. When not specified, it
defaults to 0.0.
- kgrav
- Double
- Defines the acceleration due to gravity in the global Z direction.
- The kgrav attribute is optional. When not specified, it
defaults to 0.0.
Specify gravity on the surface of the Earth, Jupiter, and the Sun in
m/s
2.
# Earth
Accgrav (kgrav=-9.81)
# Jupiter
Accgrav (kgrav=-24.79)
# Sun
Accgrav (kgrav=-274.87)
