.bdst file
The .bdst file is an OptiStruct ASCII format results file.
File Creation
This file is created in a static analysis run when the BORE Bulk Data Entry(s) are present in the model. The .bdst file contains Bore Deformation results at various Bore Depths (Z-Depth). These results are defined at all the Orders up to the order defined on the ORDER field on the BORE Bulk Data Entry.
File Contents
| Result | Description |
| Bore Deformation | Bore Deformation output
from Static Analysis. Output is controlled by the BORE Bulk Data Entry. |
File Format
| For each Bore (BORE entry), the following header is used: | |||
| Z-depth | order# i | ||
- Z-depth
- Bore depth at the Layer under consideration.
- Order# i
- The Fourier Series Order up to the ORDER defined on the BORE entry.
- This file is only output when the BORE entry is present in the input deck.
