OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
Test No. FV2 A pin-ended double cross, in-plane vibration problem. OptiStruct is used to investigate the coupling between flexural and extensional behavior, as well as the repeated and closed
eigenvalues of the double cross in Normal Modes Analysis.
Test No. FV4 This problem tests the behavior of coupling between torsional and flexural, off-center inertial axis, and close eigenvalues.
OptiStruct is used in this normal modes analysis.
Test No. FV5OptiStruct tests the repeated eigenvalues, shear deformation, and rotary inertia. The possibility of missing extensional modes
is also investigated.
Test No. FV12 A thin square plate model that contains three rigid body modes. OptiStruct investigates the repeated eigenvalues and kinematically incomplete suppressions of the thin plate in Normal Modes
Analysis.
Test No. FV16 A cantilevered thin square plate of 10 m × 10 m dimension. OptiStruct is used to investigate the frequencies at different modes for different test cases.
Test No. FV32 A tapered membrane problem with irregular mesh. The geometry and mesh symmetry are maintained along the x-direction.
The shear behavior of membrane elements in Normal Modes Analysis is examined using OptiStruct.
Test No. FV41 A free cylinder with axisymmetric vibration. OptiStruct is used to investigate the rigid body mode, close eigenvalues, and the coupling between axial, radial and circumferential
behavior.
Test No. FV52 A well-established solid square plate, which contains three rigid modes with the given boundary condition. The test
examines the performance of OptiStruct Normal Modes Analysis on 3D solid elements.
A vertical clamped free cylindrical shell with a rigid bottom is chosen to demonstrate the applicability of the structures
which are partially filled such as liquid storage tanks.
OS-V: 0400 Pin-ended Double Cross Test No. FV2 A pin-ended double cross, in-plane vibration problem. OptiStruct is used to investigate the coupling between flexural and extensional behavior, as well as the repeated and closed eigenvalues of the double cross in Normal Modes Analysis.
OS-V: 0410 Cantilever with Off-Center Point Masses Test No. FV4 This problem tests the behavior of coupling between torsional and flexural, off-center inertial axis, and close eigenvalues. OptiStruct is used in this normal modes analysis.
OS-V: 0415 Deep Simply-Supported Beam Test No. FV5OptiStruct tests the repeated eigenvalues, shear deformation, and rotary inertia. The possibility of missing extensional modes is also investigated.
OS-V: 0420 Free Thin Square Plate Test No. FV12 A thin square plate model that contains three rigid body modes. OptiStruct investigates the repeated eigenvalues and kinematically incomplete suppressions of the thin plate in Normal Modes Analysis.
OS-V: 0430 Cantilevered Thin Square Plate Test No. FV16 A cantilevered thin square plate of 10 m × 10 m dimension. OptiStruct is used to investigate the frequencies at different modes for different test cases.
OS-V: 0440 Cantilevered Tapered Membrane Test No. FV32 A tapered membrane problem with irregular mesh. The geometry and mesh symmetry are maintained along the x-direction. The shear behavior of membrane elements in Normal Modes Analysis is examined using OptiStruct.
OS-V: 0450 Free Cylinder: Axisymmetric Vibration Test No. FV41 A free cylinder with axisymmetric vibration. OptiStruct is used to investigate the rigid body mode, close eigenvalues, and the coupling between axial, radial and circumferential behavior.
OS-V: 0455 Simply-Supported Solid Square Plate Test No. FV52 A well-established solid square plate, which contains three rigid modes with the given boundary condition. The test examines the performance of OptiStruct Normal Modes Analysis on 3D solid elements.
