OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
Test No. LE1 The model is a thin plate of thickness 0.1m subjected to a uniform pressure for linear static analysis. OptiStruct examines the direct stress at the point on inside the ellipse on the x-axis.
Test No. LE3 The model is a hemispherical shell subjected to concentrated radial loads at its free edges. It examines the performance
of the three-dimensional shell to model local bending behavior under conditions where the deformations are
primarily due to bending.
Test No. LE10 The model is a thick plate subjected to uniform normal pressure of 1 MPa on the upper surface of the plate. OptiStruct examines the direct stress at the point D for linear static analysis.
Test No. LE11 The model is a thick solid cylinder subjected to linear temperature gradient in the radial and axial direction. OptiStruct examines the direct stress at the point A inside the cylinder on the y axis for linear static analysis.
This problem examines the expansion of a pressure vessel due to an internal pressure. OptiStruct examines the principal stresses in the pressure vessel, due to the applied loading and boundary conditions.
OS-V: 0010 Elliptic Membrane Test No. LE1 The model is a thin plate of thickness 0.1m subjected to a uniform pressure for linear static analysis. OptiStruct examines the direct stress at the point on inside the ellipse on the x-axis.
OS-V: 0020 Cylinder Shell Patch Test No. LE2OptiStruct examines the outer surface tangential stress at point E for linear static analysis.
OS-V: 0030 Radial Point Load on a Hemisphere Test No. LE3 The model is a hemispherical shell subjected to concentrated radial loads at its free edges. It examines the performance of the three-dimensional shell to model local bending behavior under conditions where the deformations are primarily due to bending.
OS-V: 0040 Z-Section Cantilever Test No. LE5OptiStruct examines the axial (x-x) stress (compression) at mid-surface, point A for linear static analysis.
OS-V: 0050 Skew Plate Normal Pressure Test No. LE6OptiStruct examines the maximum principal stress on the lower surface at the plate center point E for linear static analysis.
OS-V: 0060 Thick Plate Pressure Test No. LE10 The model is a thick plate subjected to uniform normal pressure of 1 MPa on the upper surface of the plate. OptiStruct examines the direct stress at the point D for linear static analysis.
OS-V: 0070 Solid Cylinder/Taper/Sphere - Temperature Test No. LE11 The model is a thick solid cylinder subjected to linear temperature gradient in the radial and axial direction. OptiStruct examines the direct stress at the point A inside the cylinder on the y axis for linear static analysis.
OS-V: 0085 Plane Strain: Analysis of Pressure Vessel
