Export a green part as a .stl file. You can select from several simulation
runs.
First, run a compensation analysis on your part. The
compensation analysis calculates the shape for the green part, which will settle into
the desired shape during the sintering process.
Click the Green Part
icon to open a microdialog.
Select a run from the drop-down menu.
Click the Export button.
Name and save the .stl file.
