Configure the oven. You can select a default oven or choose from several standard
ovens.
Click the Oven icon to configure the oven.
Select an oven from the drop-down menu, or customize the printing bed using the
X, Y, and Z dimensions. If you do not yet know which oven to use, select the
default option.
