Gravity
Use the Gravity tool to apply gravitational acceleration (G) and adjust its direction.
Gravity is applied to the entire model, and is saved with the model file. You can turn gravity on and off using the settings in the Run Optimization or Run Analysis window.
Set Gravity
Enter a gravitational acceleration and define the direction of gravity.
- There are two ways to define gravity in your model. You can enter a magnitude and a direction vector (X, Y, Z), or you can enter the gravity by its vector components (Gx, Gy, Gz). If you enter component values, the magnitude is automatically recalculated.
 - If you want to exclude gravity from optimization or analysis, you can either set the magnitude for the gravitational acceleration to 0, or change the gravity setting in the Run Optimization or Run Analysis settings.
Microdialog Options
Use the options in the microdialog to edit the direction and alignment of the gravity vector.
| Reverse Direction of the Magnitude | Reverse the direction of gravity (G). |
| Set Magnitude | Enter a magnitude for the gravitational acceleration. Click the  |
| Direction Gravity Mode/Component Gravity Mode | Use to change how gravity is defined. You can enter a magnitude and a direction
              Click the
              to define the direction or component vectors. |
| Rotate | Rotate the direction of gravity (G) using the Move tool. |
| Align to X, Y, Z Global Axis | Align gravity to the negative X, Y, or Z direction. Click a second time to align in the positive direction. |
| Set X, Y, Z Axis Component | Click the   to define the direction of gravity by entering direction
              vectors for X, Y, and Z. (For example, entering 1, 0, 0 would orient it in the
              positive x direction.) |
| Set Gx, Gy, Gz Component | Click the   to define the direction of gravity by entering gravity
              component vectors for Gx, Gy, and Gz. (For example, entering 0, 0, - 9.81 would orient
              it in the negative z direction.) |
Mouse Controls and Keyboard Shortcuts
| Right-click and mouse through the check mark to exit, or double-right-click. | Press Esc or RMB. |
 or
                        component gravity mode
, then click the
 to define a
