Connectors link points, edges, or faces to each other, and are shown as red lines radiating from a central point.
They are generally used to connect two parts together, or to apply a load or support at a distance.
You can define Contacts as bonded, sliding, separating, or no contact. When running SimSolid analysis, you can have a mixed case of sliding and
separating contacts. When running OptiStruct analysis, all contacts must be either sliding or separating.
Create and define connections such as fasteners, joints, connectors, spot welds, and
contacts.
Fasteners
Fasteners connect parts together without allowing movement at the hole location.
Joints
Use the Joints tool to connect parts together while allowing movement at the joint location.
Bushings
Create bushings between the selected surfaces of the parts.
Connectors
Connectors link points, edges, or faces to each other, and are shown as red lines radiating from a central point. They are generally used to connect two parts together, or to apply a load or support at a distance.
Spot Welds
Spot welds connect parts together by welding them at specific locations.
Contacts
You can define Contacts as bonded, sliding, separating, or no contact. When running SimSolid analysis, you can have a mixed case of sliding and separating contacts. When running OptiStruct analysis, all contacts must be either sliding or separating.
