Select one or more bushings to change their properties.
To review all bushings and edit their names and properties in one place, see
Open the Bushings Table.
On the Structures ribbon, select the Bushings
tool.
Select the bushings that you want to edit.
Note: While holding down Ctrl,
click to multi-select and deselect.
In the guide panel, you can change or add new linear stiffness properties
(TX, TY,
TZ) or rotational stiffness properties
(RX, RY,
RZ).
Note: If multiple bushings with different properties are
selected, the fields will be blank.
You can change the Mass.
Click Create the Bushing
The changes will be applied.
In the microdialog, you can do the following:
Option |
Description |
Align to Global Axes
Align to the global axes. |
Move
Translate or rotate using the Move tool. |
Add/Remove
Add/remove faces from the selected bushings. |
Set Origin X |
Set the origin coordinate in the X direction. |
Set Origin Y |
Set the origin coordinate in the Y direction. |
Set Origin Z |
Set the origin coordinate in the Z direction. |
Right-click and mouse through the check mark to exit, or double-right-click.
