Run Analysis
Use the Run Analyis window to set up and run a simulation.
Select the Run Analysis
            tool on one the Analyze icons to define settings for the desired type of analysis
            (structures, motion, print3D, etc.)
- Some of the Analyze tools, such as Motion, feature a quick run
 button that automatically runs the analysis with the
                default settings. To change the settings, click the
 icon
                that appears when you hover over the Analyze tool. - The Optimize and Optimize Part tools that appear on the Structures and Motion ribbon work similarly to the Analyze icons. When the optimizaiton is complete, Inspire will open the Shape Explorer rather than the Analysis Explorer.
