Inspire is a concept design tool, which you can use to run structural optimization, finite element analysis, motion analysis,
and additive manufacturing analysis.
Modify the workspace display, default keyboard shortcuts, and other
settings.
Open the Preferences
Open the Preferences window, where you can search for and customize application settings.
Search the Preferences
Search for a setting to show the closest match in the Preferences window. Or use the API to display selectable search results in a dropdown list.
Preferences: Workspace
Define preferences for the user interface, including the display and language.
