Define preferences for 3D printing.
    Undercut Options
                | Preference |
                Description |
                | Minimum support area |
                Use to define the smallest area for which supports should be generated. Areas
                  smaller than this will be assumed to be self-supporting due to their small size
                  and will not display a support preview, even if one would generally be required
                  due to the undercut angle. |
                | Angle undercut |
                Any region with an undercut angle less than or equal to the value defined
                  here will be shown as requiring supports. |
    Support Options
                | Preference |
                Description |
                | Support spacing |
                Use to adjust the spacing between supports. |
    Run Options
                | Preference |
                Description |
                | Run in model directory |
                Enable this option if you want to store run history in the directory where
                  the model is located rather than the run history path. |
                | Run history path |
                Specify the default location where the run history is stored. |
                | Number of CPU cores |
                The number of CPU cores used during analysis runs. For larger models,
                  significant time savings can be achieved by using at least two cores to perform
                  the calculation. |
    Analysis Legend Colors
                | Preference |
                Description |
                | Printing |
                Select the legend color scheme for Print 3D analysis results. |
