Inspire is a concept design tool, which you can use to run structural optimization, finite element analysis, motion analysis,
and additive manufacturing analysis.
CAD import occurs in three steps: (1) pre-processing, (2) conversion from a third-party format to Parasolid where
applicable, and (3) post-processing of the Parasolid model.
Learn about the CAD import process and cleaning up CAD on import.
CAD Import Process
CAD import occurs in three steps: (1) pre-processing, (2) conversion from a third-party format to Parasolid where applicable, and (3) post-processing of the Parasolid model.
Clean Up CAD on Import
Run a diagnostic test on the imported model to review and fix issues with parts.
