Organizing tool components is an important step and can be performed anytime while setting up the model, but would
ideally be organized immediately after cleaning the geometry.
This feature enables you to create gap contacts between two tool parts. This tool automatically detects possible contacts
in your model for the displayed parts.
Use the Show Analysis Results tool to view the results of an analysis in the Analysis Explorer. View and animate results,
add callouts, and compare results from different runs.
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past
runs, you need to view the run history.
