Organizing tool components is an important step and can be performed anytime while setting up the model, but would
ideally be organized immediately after cleaning the geometry.
This feature enables you to create gap contacts between two tool parts. This tool automatically detects possible contacts
in your model for the displayed parts.
Orienting and Positioning the Model
Use the Orient tool to set the orientation direction for an extruded profile and correctly position the model along the Z-axis.
Simplifying Geometry
Use the Simplify tool to plug holes and pockets and to remove imprints, rounds, fillets, holes, and pockets.
Organizing Tool Components
Organizing tool components is an important step and can be performed anytime while setting up the model, but would ideally be organized immediately after cleaning the geometry.
Setting up Load Faces
Use the Load Faces tool to add or remove load faces from the existing set of load surfaces.
Setting up Boundary Conditions
Set boundary conditions for Tool Deflection analysis, which requires loads and constraints.
Creating Gap Contacts
This feature enables you to create gap contacts between two tool parts. This tool automatically detects possible contacts in your model for the displayed parts.
Selecting Materials
Use the Materials tool to select materials for the analysis.
Performing Job Analysis
Use the Analysis tool to submit the job for analysis, inspect the job status, perform post-processing and review job history.
