CAD Preparation Guidelines
Typically, the starting point of analysis for Inspire Extrude is a CAD file of die assembly.
Orienting and Positioning the Model
Use the Orient tool to set the orientation direction for an extruded profile and correctly position the model along the Z-axis.
Extracting Flow Volume
Use the Flow Volume tool to create the flow volume to analyze the deformation of the material.
