Selecting the Press
Use the Press Data tool to select the press.
Press selection can be done anytime during the model setup; however, it has to be complete before running the analysis.
  1. From the Extrusion ribbon, click the Press Data tool.
    The Press Database dialog is displayed.
  2. Select the desired press.
  3. Right-click on the selected press and select Edit to edit the press data.
  4. Click Update to save the changes.
