When running an analysis, automatically export your model and perform advanced
meshing in SimLab.
Prerequisite: You must have SimLab installed for this
feature to work.
Click Run Analysis on the Analyze icon.
On the Advanced tab, select Use advanced meshing with
SimLab.
Click the Run button. As part of the analysis, SimLab
will be launched and your model automatically imported.
In SimLab, select the Molding tab.
Use the Mesh Controls, Surface
Mesh, and Volume Mesh tools to perform
advanced meshing.
- Mesh Controls: Modify any aspect of the mesh,
including the geometry, and features such as fillets and washers, and logos,
etc.
- Surface Mesh: Once the mesh controls have been
modified, use this tool to generate, visualize, and query the surface
mesh.
- Volume Mesh: After adjusting the mesh controls
and iterating on the surface mesh, use this tool to generate the volume
mesh.
When finished meshing, select the Save and Exit icon on
the ribbon.
Your model will be exported back to Inspire Mold, and the
analysis will resume.
