Show, Hide, and Isolate
Show, hide, and isolate objects in the modeling window using keyboard shortcuts.
To Do this Note
Show/hide selected objects
  • Press H.
  • Right-click the selection in the modeling window or Model Browser, and then select Hide Selected from the context menu.
You can also show or hide objects by:
  • Clicking their icons in the Model Browser.
  • Using the show and hide options in the right-click (context) menu.
  • Using the Show/Hide Mode tool in the view controls.
  • Using the View menu.
Isolate selected objects (parts, assemblies, sketches, faces, and reference entities)
  • Press I.
  • Right-click the selection in the modeling window or Model Browser, and then select Isolate from the context menu.
  • To isolate faces, in the view controls, select Show/Hide Mode , select Isolate , and then select the desired faces.
Isolating an object zooms in and temporarily hides all other objects.
Show all/hide all objects
  • Press A.
  • Right-click an object in the modeling window or Model Browser, and then select Show All or Hide All from the context menu.
  • In the view controls, select Show/Hide Mode . Then select Show All or Hide All .
Reverse the selection
  • Press R.
  • Right-click the selection in the modeling window or Model Browser, and then select Reverse Selected from the context menu.
Temporarily turn selected parts transparent Hold down Ctrl.
