Passive Device Stability
This item checks whether the filter installed in the IO terminal is well designed with low impedance.
- Item: Input item name.
- Net Group: Set IO net group to which filter is connected.
- Start Component: Set IO component group filter that should be used.
- Passive Component: Set filter component group.
- Test Option
- A Side Check (Trace Only): Option for connection path test between
filter and component.
Figure 1. - Check minimum trace width: DFE checks the minimum width of trace between Filter and Component.
- Check maximum distance: DFE checks the maximum distance between Filter and Component.
- Check maximum trace length: DFE checks the maximum trace length between Filter and Component.
- B Side Check (Trace Only): Option for connection path test between
filter and ground.
Figure 2. - Minimum polygon size to be considered as stable PWR/GND: Defines the minimum size of a polygon that can be considered a stable ground. When performing the following tests, DFE calculates and checks the total length of the entire path connected from the filter to the stable ground.
- Check trace length to stable PWR/GND: DFE checks the path
between Filter and stable ground.
Maximum total trace length: DFE checks the maximum trace length between Filter and stable ground.
Maximum total segment length/width ratio: DFE checks the maximum trace length/width ratio between Filter and stable ground.
- Considered as pass if one good path to stable PWR/GND exist: If there are multiple connection paths between Filter and Stable Ground, if even one path satisfies the criteria, the whole is judged as a pass.
- Test Options: Common test option
- Passive Component PAD should be connected to Net directly: The DFE
checks whether the PAD of the filter is placed directly onto the
main net.
- End Component: The DFE determines that the path where the Start Component and this End Component are connected is the main route.
- Passive Component should be placed on the same layer with Component: DFE checks whether the filter is placed on the same side as the start component.
- Include VIA length: The length of VIA is also included when
calculating net length.
- VIA Length Compensation: Since the inductance of VIA is different from the inductance of trace, this factor is used when calculating the effective length of VIA.
main net.
